Philco Model 96 Restoration Info
TNA yes the yellow caps are 630V. The black caps are Solen Fast Caps which I prefer over low value e-caps. They too are 630 V. They are larger than e-caps but room is not a problem. Standard 450V e-caps will work fine as well. You should restuff the tone control caps as well. All three 630V will be fine. You will find that easy compared to the big can!
Good luck, Jerry
Philco Model 96 Restoration Info - by TN Allen - 08-28-2013, 01:04 PM
RE: Philco Model 96 Restoration Info - by Eric T - 08-28-2013, 09:21 PM
RE: Philco Model 96 Restoration Info - by Jamie - 08-29-2013, 06:50 AM
RE: Philco Model 96 Restoration Info - by jerryhawthorne - 09-11-2013, 02:12 PM
RE: Philco Model 96 Restoration Info - by Jamie - 09-15-2013, 12:52 PM
RE: Philco Model 96 Restoration Info - by sam - 09-15-2013, 01:04 PM
RE: Philco Model 96 Restoration Info - by sam - 01-15-2015, 01:55 PM
