Threads: 27
City: Boulder, Colorado
Hi All;
Nope, all the Papers are done, I have the Bakelite to do, but it will be later.. It also now squeels when I turn up the Volume, I don't know if this is related.. It still also pops.. And then no sound..
THANK YOU Marty
(This post was last modified: 09-11-2013, 05:06 PM by marty.)
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 05:05 PM
Quick progress report:
Hi Rod,
Hello Tim,
Hello Tim,
There are currently 8515 online users. [Complete List] » 3 Member(s) | 8512 Guest(s)
