Goes Dead, Philco 45
Hi All;
Jerry, Too late I have already re-placed the two 220PF Caps.. And So Far its is working, but it just went out.. About 3 to 5 minutes..
No signal from touching the Grid caps, But, it just Came back on all by it self, played for a little while then it Squeeled, I switched the Band switch and switched it back the squeeling went away for a little while and now it squeels on both bands.. I have had to turn it off..
There is crackingling while I type and such movement on the kitchen table..
Time for Bed, I will hopefully continue tomorrow night.. When I am fresh I will take voltage readings both before and after..
But, Please, Please give my Your "Input" and suggestions..
THANK YOU Marty
Goes Dead, Philco 45 - by marty - 09-11-2013, 12:38 PM
RE: Goes Dead, Philco 45 - by codefox1 - 09-11-2013, 12:54 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 01:06 PM
RE: Goes Dead, Philco 45 - by morzh - 09-11-2013, 01:47 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 02:09 PM
RE: Goes Dead, Philco 45 - by Warren - 09-11-2013, 02:52 PM
RE: Goes Dead, Philco 45 - by morzh - 09-11-2013, 02:59 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 03:29 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 04:22 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 05:05 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 06:28 PM
RE: Goes Dead, Philco 45 - by morzh - 09-11-2013, 07:50 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-11-2013, 07:53 PM
RE: Goes Dead, Philco 45 - by BrendaAnnD - 09-11-2013, 08:10 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-11-2013, 08:31 PM
RE: Goes Dead, Philco 45 - by morzh - 09-11-2013, 08:50 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 10:23 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-11-2013, 10:55 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 11:06 PM
RE: Goes Dead, Philco 45 - by morzh - 09-12-2013, 09:28 AM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 11:56 AM
RE: Goes Dead, Philco 45 - by BrendaAnnD - 09-13-2013, 12:17 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 12:27 PM
RE: Goes Dead, Philco 45 - by morzh - 09-13-2013, 01:59 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 02:04 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-13-2013, 03:06 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 03:18 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-13-2013, 03:53 PM
RE: Goes Dead, Philco 45 - by morzh - 09-13-2013, 03:59 PM
RE: Goes Dead, Philco 45 - by BrendaAnnD - 09-13-2013, 05:29 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 06:12 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-13-2013, 06:43 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 06:56 PM
RE: Goes Dead, Philco 45 - by Mondial - 09-13-2013, 06:57 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 07:04 PM
RE: Goes Dead, Philco 45 - by Radioroslyn - 09-13-2013, 07:31 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 07:35 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 07:39 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 07:52 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-13-2013, 07:57 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 08:04 PM
RE: Goes Dead, Philco 45 - by Mondial - 09-13-2013, 08:10 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-13-2013, 08:12 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-13-2013, 08:19 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 08:23 PM
RE: Goes Dead, Philco 45 - by Radioroslyn - 09-13-2013, 08:32 PM
RE: Goes Dead, Philco 45 - by BrendaAnnD - 09-13-2013, 08:41 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 08:48 PM
RE: Goes Dead, Philco 45 - by BrendaAnnD - 09-13-2013, 08:56 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 09:17 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 10:47 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-13-2013, 11:04 PM
RE: Goes Dead, Philco 45 - by Radioroslyn - 09-14-2013, 07:01 AM
RE: Goes Dead, Philco 45 - by marty - 09-14-2013, 09:14 AM
RE: Goes Dead, Philco 45 - by Mondial - 09-14-2013, 09:23 AM
RE: Goes Dead, Philco 45 - by marty - 09-14-2013, 09:42 AM
RE: Goes Dead, Philco 45 - by Radioroslyn - 09-14-2013, 07:24 PM
Users browsing this thread: 14 Guest(s)
There are currently 10266 online users. [Complete List]
» 1 Member(s) | 10265 Guest(s)
