O man now I've done it, Philco 37-116
City: Sedona, AZ/Placentia/CA
I don't know how you do it over there Brenda but keep up the great radio work and the help you provide others. It can't be easy or safe to get nice radios over there in one piece.
Regards, Jerry
RE: O man now I've done it, Philco 37-116 - by jerryhawthorne - 09-11-2013, 11:20 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
