New and lost. 40-190
Fossil, no problem here, we are patient. For melting the solder, make sure your tip is clean, I have a damp sponge to wipe it across, then wick it with some solder. Generally 20 watts is just fine. Lots of wires on it, I will kick it up to 40 watts.
Good luck, Jerry
New and lost. 40-190 - by Fibber Mcgee - 09-09-2013, 03:12 AM
RE: New and lost. 40-190 - by Radioroslyn - 09-09-2013, 07:29 AM
RE: New and lost. 40-190 - by jerryhawthorne - 09-09-2013, 12:55 PM
RE: New and lost. 40-190 - by EricS - 09-09-2013, 05:39 PM
RE: New and lost. 40-190 - by Fibber Mcgee - 09-10-2013, 12:22 AM
RE: New and lost. 40-190 - by Radioroslyn - 09-10-2013, 07:10 AM
RE: New and lost. 40-190 - by fossilexpress - 09-11-2013, 10:02 PM
RE: New and lost. 40-190 - by jerryhawthorne - 09-12-2013, 12:23 AM
RE: New and lost. 40-190 - by Fibber Mcgee - 09-13-2013, 05:13 PM
RE: New and lost. 40-190 - by jerryhawthorne - 09-13-2013, 05:48 PM
RE: New and lost. 40-190 - by marty - 09-13-2013, 06:33 PM
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
