41-608 BOL Adjustments
david looking down on top of chassis to the left of turner is 3 screws schematic says 37 and 37a but it dose not say which is which looking at my spare chassis looks like center one is 37a goes to coil hope it helps
if I am wrong some one please chime in
41-608 BOL Adjustments - by davidff - 09-11-2013, 11:12 AM
RE: 41-608 BOL Adjustments - by sam - 09-11-2013, 11:36 AM
RE: 41-608 BOL Adjustments - by marv - 09-11-2013, 05:14 PM
RE: 41-608 BOL Adjustments - by davidff - 09-12-2013, 10:56 AM
RE: 41-608 BOL Adjustments - by sam - 09-12-2013, 01:53 PM
There are currently 4112 online users. [Complete List]
» 1 Member(s) | 4111 Guest(s)
