  • 1 Vote(s) - 5 Average
Philco 40-145 Cabinet Repair
Here is the victim. A Philco 40-145 I picked up at a flea market. The major problem was the wooden surround on the dial. Most of the top was missing. There were also issues with the veneer. Pieces were missing from the top right above the dial, and on both sides. The bottom right was a pretty big chunk that was gone. Also, above each push button, the veneer was gone.
Philco 40-145 Cabinet Repair - by Jamie - 09-12-2013, 05:10 PM
RE: Philco 40-145 Cabinet Repair - by Jamie - 09-12-2013, 05:17 PM
RE: Philco 40-145 Cabinet Repair - by Jamie - 09-12-2013, 05:26 PM
RE: Philco 40-145 Cabinet Repair - by Jamie - 09-12-2013, 05:32 PM
RE: Philco 40-145 Cabinet Repair - by Jamie - 09-12-2013, 05:40 PM
RE: Philco 40-145 Cabinet Repair - by EricS - 09-12-2013, 06:14 PM
RE: Philco 40-145 Cabinet Repair - by Jamie - 09-12-2013, 06:48 PM
RE: Philco 40-145 Cabinet Repair - by sam - 09-12-2013, 10:44 PM
RE: Philco 40-145 Cabinet Repair - by Jamie - 09-13-2013, 08:07 AM
RE: Philco 40-145 Cabinet Repair - by Ron Ramirez - 09-13-2013, 08:40 AM
RE: Philco 40-145 Cabinet Repair - by Jamie - 09-13-2013, 08:50 AM
RE: Philco 40-145 Cabinet Repair - by klondike98 - 09-13-2013, 10:23 AM
There are currently 8777 online users. [Complete List]
» 2 Member(s) | 8775 Guest(s)
