37-11 Rectifier
Now that is odd. I just looked at the service bulletin for your set; it calls for a 5Y4G rectifier. I also checked the Changes in Models sheets; no mention of a different rectifier.
A 5Y4G is electrically the same as a 5Y3G; except that the basing is different. Either should be adequate to power the 37-11.
37-11 Rectifier - by AI2V - 03-16-2008, 09:29 PM
[No subject] - by Ron Ramirez - 03-16-2008, 10:31 PM
5Y3/5Y4 - by AI2V - 03-17-2008, 09:32 AM
Philco 91 Tuning Condenser
There are currently 6881 online users. [Complete List]
» 2 Member(s) | 6879 Guest(s)
