Knob glued to shaft
Icon_sad has anyone faced a knob that has been glued to the shaft of a switch??
Any ideas on getting it off? I'm almost at the point of trying to cut the shaft and then try to find a new switch an knob. With the chassis loose I can get a small space between the knob and the cabinet but that's my last resort.
Knob glued to shaft - by klondike98 - 09-12-2013, 07:05 PM
RE: Knob glued to shaft - by murf - 09-12-2013, 07:14 PM
RE: Knob glued to shaft - by Jamie - 09-12-2013, 07:18 PM
RE: Knob glued to shaft - by klondike98 - 09-12-2013, 07:41 PM
RE: Knob glued to shaft - by Jamie - 09-12-2013, 07:46 PM
RE: Knob glued to shaft - by Arran - 09-12-2013, 07:48 PM
RE: Knob glued to shaft - by klondike98 - 09-12-2013, 07:52 PM
RE: Knob glued to shaft - by Jamie - 09-12-2013, 08:28 PM
RE: Knob glued to shaft - by klondike98 - 09-12-2013, 08:44 PM
RE: Knob glued to shaft - by klondike98 - 09-13-2013, 02:15 PM
RE: Knob glued to shaft - by klondike98 - 09-13-2013, 07:57 PM
RE: Knob glued to shaft - by murf - 09-13-2013, 08:34 PM
RE: Knob glued to shaft - by EricS - 09-17-2013, 07:58 PM
RE: Knob glued to shaft - by klondike98 - 09-17-2013, 09:18 PM
There are currently 11359 online users. [Complete List]
» 2 Member(s) | 11357 Guest(s)
