118 By-pass cap box
I am using 400V caps because that is what happen to have. I would prefer 630V ones, but they are a bit more difficult to find in 1 uF ( I am using two in parallel for the 2 uF cap ). Actually, in circuit they will be only about 200 to 250V max across them in normal use.
During warm-up when the rectifier filament is hot but the remaining tubes heaters are still warming up, there will be momentarily higher voltages across some of the caps, but not significantly more than 400V.
Cap 28 ( rated 450V ) sees the most voltage because before the 6A7 warms up, the cap is connected directly to the B+ supply through 20K resistor 26 without any voltage drop from tube current. The remaining caps see less voltage because of voltage divider resistors.
118 By-pass cap box - by hunter2115 - 09-12-2013, 04:47 PM
RE: 118 By-pass cap box - by Radioroslyn - 09-12-2013, 05:15 PM
RE: 118 By-pass cap box - by Mondial - 09-12-2013, 06:22 PM
RE: 118 By-pass cap box - by hunter2115 - 09-12-2013, 06:33 PM
RE: 118 By-pass cap box - by TA Forbes - 09-12-2013, 08:18 PM
RE: 118 By-pass cap box - by Mondial - 09-12-2013, 08:18 PM
RE: 118 By-pass cap box - by BrendaAnnD - 09-12-2013, 08:32 PM
RE: 118 By-pass cap box - by hunter2115 - 09-12-2013, 08:55 PM
RE: 118 By-pass cap box - by Mondial - 09-12-2013, 10:35 PM
RE: 118 By-pass cap box - by BrendaAnnD - 09-12-2013, 11:41 PM
RE: 118 By-pass cap box - by jerryhawthorne - 09-13-2013, 10:59 PM
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
Philco 630csx power cord
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
There are currently 2225 online users. [Complete List]
» 2 Member(s) | 2223 Guest(s)
