Philco 37-116 and Zenith 9S-262
I never had anything worse to re-cap than 37-116 but them my experience is limited.
Restoration includes other things, and between replacing a whole lot of tightly packed rubber wire and recapping 37-116 I am not sure which one I'd choose.
If it weren't for the RF chassis hidden caps, 37-116 would be not so bad at all, if not easy.
And, of course, soldered rivets in backelite caps did not help....
Philco 37-116 and Zenith 9S-262 - by morzh - 09-07-2013, 02:46 PM
RE: Philco 37-116 and Zenith 9S-262 - by morzh - 09-07-2013, 04:26 PM
RE: Philco 37-116 and Zenith 9S-262 - by morzh - 09-07-2013, 04:56 PM
RE: Philco 37-116 and Zenith 9S-262 - by morzh - 09-11-2013, 11:59 AM
RE: Philco 37-116 and Zenith 9S-262 - by morzh - 09-13-2013, 03:14 PM
RE: Philco 37-116 and Zenith 9S-262 - by morzh - 09-14-2013, 05:03 PM
RE: Philco 37-116 and Zenith 9S-262 - by morzh - 09-15-2013, 04:59 PM
RE: Philco 37-116 and Zenith 9S-262 - by morzh - 09-21-2013, 07:29 PM
There are currently 8312 online users. [Complete List]
» 3 Member(s) | 8309 Guest(s)
