Picked Up Two Consoles Today
Wow you will love the RCA-813. I have a RCA 816 and love it. Plays nice and strong.. Should not be too much difference to mine. And yours cost a whole lot less also.....Godd luck with it!
Picked Up Two Consoles Today - by Gene Pederson - 08-04-2013, 03:17 PM
RE: Picked Up Two Consoles Today - by murf - 08-04-2013, 04:14 PM
RE: Picked Up Two Consoles Today - by Jayce - 08-04-2013, 04:49 PM
RE: Picked Up Two Consoles Today - by PhilcoMike - 08-05-2013, 04:19 PM
RE: Picked Up Two Consoles Today - by Arran - 08-06-2013, 03:50 AM
RE: Picked Up Two Consoles Today - by PhilcoJohn - 09-13-2013, 06:45 PM
RE: Picked Up Two Consoles Today - by TA Forbes - 09-19-2013, 02:54 PM
