New Arrival
Heck of a lot easier to do the finishing work on and it's cheap. All I can tell you is you better wear a doodad protector if your going to pick it up!! I had one years ago, it was a brown wrinkle job with a single 71 in the audio think it was a 52 ( this has P/P 71's) Best I can remember it use a cone speaker like the mdl 40. Sounded like a model 40. This set has a dynamic speaker so it should sound pretty good for 1929 technology. Between the larger power supply and the electrodynamic speaker it's a killer to move.
New Arrival - by Radioroslyn - 09-13-2013, 06:42 PM
RE: New Arrival - by PhilcoJohn - 09-13-2013, 06:49 PM
RE: New Arrival - by Radioroslyn - 09-13-2013, 07:02 PM
RE: New Arrival - by Electrothaumaturgist - 09-13-2013, 07:43 PM
RE: New Arrival - by morzh - 09-13-2013, 09:11 PM
RE: New Arrival - by Jayce - 09-13-2013, 10:33 PM
RE: New Arrival - by NostalgiaRadioTime - 09-14-2013, 12:36 AM
RE: New Arrival - by Radioroslyn - 09-14-2013, 07:39 AM
RE: New Arrival - by sam - 09-14-2013, 01:37 PM
RE: New Arrival - by TimC - 09-14-2013, 02:57 PM
RE: New Arrival - by Radioroslyn - 09-15-2013, 11:56 PM
RE: New Arrival - by PAradiogeek - 09-16-2013, 03:46 PM
RE: New Arrival - by Radioroslyn - 09-16-2013, 06:05 PM
RE: New Arrival - by PAradiogeek - 09-17-2013, 07:38 AM
RE: New Arrival - by Radioroslyn - 09-17-2013, 10:29 AM
RE: New Arrival - by Jamie - 09-17-2013, 03:44 PM
There are currently 7831 online users. [Complete List]
» 3 Member(s) | 7828 Guest(s)
