Goes Dead, Philco 45
#36
You can switch the 41 for a 42 in this set. If your heater is going out on the 42 tube it isn't going to be drawing any current from the HV. That's what's causing the voltage to change on your large resistor.
Goes Dead, Philco 45 - by marty - 09-11-2013, 12:38 PM
RE: Goes Dead, Philco 45 - by codefox1 - 09-11-2013, 12:54 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 01:06 PM
RE: Goes Dead, Philco 45 - by morzh - 09-11-2013, 01:47 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 02:09 PM
RE: Goes Dead, Philco 45 - by Warren - 09-11-2013, 02:52 PM
RE: Goes Dead, Philco 45 - by morzh - 09-11-2013, 02:59 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 03:29 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 04:22 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 05:05 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 06:28 PM
RE: Goes Dead, Philco 45 - by morzh - 09-11-2013, 07:50 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-11-2013, 07:53 PM
RE: Goes Dead, Philco 45 - by BrendaAnnD - 09-11-2013, 08:10 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-11-2013, 08:31 PM
RE: Goes Dead, Philco 45 - by morzh - 09-11-2013, 08:50 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 10:23 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-11-2013, 10:55 PM
RE: Goes Dead, Philco 45 - by marty - 09-11-2013, 11:06 PM
RE: Goes Dead, Philco 45 - by morzh - 09-12-2013, 09:28 AM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 11:56 AM
RE: Goes Dead, Philco 45 - by BrendaAnnD - 09-13-2013, 12:17 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 12:27 PM
RE: Goes Dead, Philco 45 - by morzh - 09-13-2013, 01:59 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 02:04 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-13-2013, 03:06 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 03:18 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-13-2013, 03:53 PM
RE: Goes Dead, Philco 45 - by morzh - 09-13-2013, 03:59 PM
RE: Goes Dead, Philco 45 - by BrendaAnnD - 09-13-2013, 05:29 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 06:12 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-13-2013, 06:43 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 06:56 PM
RE: Goes Dead, Philco 45 - by Mondial - 09-13-2013, 06:57 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 07:04 PM
RE: Goes Dead, Philco 45 - by Radioroslyn - 09-13-2013, 07:31 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 07:35 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 07:39 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 07:52 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-13-2013, 07:57 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 08:04 PM
RE: Goes Dead, Philco 45 - by Mondial - 09-13-2013, 08:10 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-13-2013, 08:12 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-13-2013, 08:19 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 08:23 PM
RE: Goes Dead, Philco 45 - by Radioroslyn - 09-13-2013, 08:32 PM
RE: Goes Dead, Philco 45 - by BrendaAnnD - 09-13-2013, 08:41 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 08:48 PM
RE: Goes Dead, Philco 45 - by BrendaAnnD - 09-13-2013, 08:56 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 09:17 PM
RE: Goes Dead, Philco 45 - by marty - 09-13-2013, 10:47 PM
RE: Goes Dead, Philco 45 - by jerryhawthorne - 09-13-2013, 11:04 PM
RE: Goes Dead, Philco 45 - by Radioroslyn - 09-14-2013, 07:01 AM
RE: Goes Dead, Philco 45 - by marty - 09-14-2013, 09:14 AM
RE: Goes Dead, Philco 45 - by Mondial - 09-14-2013, 09:23 AM
RE: Goes Dead, Philco 45 - by marty - 09-14-2013, 09:42 AM
RE: Goes Dead, Philco 45 - by Radioroslyn - 09-14-2013, 07:24 PM
Users browsing this thread: 13 Guest(s)
There are currently 9824 online users. [Complete List]
» 3 Member(s) | 9821 Guest(s)
