Truetone
Thank u all, really nothing but curious who made this puppy. It plays very strong, I got it off a fellow collector. The cabinet is too large really for the AA5 but it is a very solid set. It is aligned right on and is pretty sensitive at nite with just the Stratoscope antenna. it has 3 original tubes and is one of the cleanest chassis of any set I have.
I have heard that a well aligned set can be quite sensitive, perhaps this explains why some 5 tubers are mezza mezza and some seem to outperform their design.
I have seen cross references for makers of Silvertones and thought such a list may exist for Trutone.
Truetone - by Paul Philco322 - 09-05-2013, 07:31 PM
RE: Truetone - by Jbaker - 09-11-2013, 09:28 PM
RE: Truetone - by codefox1 - 09-12-2013, 01:41 AM
RE: Truetone - by TA Forbes - 09-12-2013, 08:56 PM
RE: Truetone - by Paul Philco322 - 09-13-2013, 08:41 PM
There are currently 9780 online users. [Complete List]
» 3 Member(s) | 9777 Guest(s)
