Philco Model 96 Restoration Info
Thank you for the information. Eventually I'll understand this better.
The tone control capacitors, 2 @ .01uF and 1 @ .015uF should be polypropylene?
And the capacitors in the "Condenser Block"(3 @ .5uF, 2 @ .015uF, 2 @ 2uF, and 1 @1uF), are they electrolytic?
Philco Model 96 Restoration Info - by TN Allen - 08-28-2013, 01:04 PM
RE: Philco Model 96 Restoration Info - by Eric T - 08-28-2013, 09:21 PM
RE: Philco Model 96 Restoration Info - by Jamie - 08-29-2013, 06:50 AM
RE: Philco Model 96 Restoration Info - by TN Allen - 09-14-2013, 01:12 PM
RE: Philco Model 96 Restoration Info - by Jamie - 09-15-2013, 12:52 PM
RE: Philco Model 96 Restoration Info - by sam - 09-15-2013, 01:04 PM
RE: Philco Model 96 Restoration Info - by sam - 01-15-2015, 01:55 PM
