Philco Model 96 Restoration Info
I looked at the Tone Control, the capacitors are in pitch within the bakelite TC body. I can remove these, or, I can also solder new capacitors to the contacts. Is it likely the original capacitors are OK? And, given the capacitors can be switched out of the circuit, can I power up the radio with the new "Condenser Block" capacitors in place?
Thanks again
Philco Model 96 Restoration Info - by TN Allen - 08-28-2013, 01:04 PM
RE: Philco Model 96 Restoration Info - by Eric T - 08-28-2013, 09:21 PM
RE: Philco Model 96 Restoration Info - by Jamie - 08-29-2013, 06:50 AM
RE: Philco Model 96 Restoration Info - by TN Allen - 09-15-2013, 11:19 AM
RE: Philco Model 96 Restoration Info - by Jamie - 09-15-2013, 12:52 PM
RE: Philco Model 96 Restoration Info - by sam - 09-15-2013, 01:04 PM
RE: Philco Model 96 Restoration Info - by sam - 01-15-2015, 01:55 PM
