Philco Model 96 Restoration Info
Yes, replace the caps in the tone switch. It is quite easy and these are handling some high voltages.
Jerry
Philco Model 96 Restoration Info - by TN Allen - 08-28-2013, 01:04 PM
RE: Philco Model 96 Restoration Info - by Eric T - 08-28-2013, 09:21 PM
RE: Philco Model 96 Restoration Info - by Jamie - 08-29-2013, 06:50 AM
RE: Philco Model 96 Restoration Info - by Jamie - 09-15-2013, 12:52 PM
RE: Philco Model 96 Restoration Info - by sam - 09-15-2013, 01:04 PM
RE: Philco Model 96 Restoration Info - by jerryhawthorne - 09-15-2013, 01:42 PM
RE: Philco Model 96 Restoration Info - by sam - 01-15-2015, 01:55 PM
