My first 1920's set
Always like a set with a lot of knobs to twittle!! Better start save your spare change for buying the 01A's to fill those sockets. And you might want to measure the resistance across the two audio transformers to see if there open, it's a common problem on battery sets.
My first 1920's set - by Groundhog74 - 09-15-2013, 08:59 PM
RE: My first 1920's set - by sam - 09-15-2013, 09:35 PM
RE: My first 1920's set - by morzh - 09-15-2013, 09:41 PM
RE: My first 1920's set - by BrendaAnnD - 09-15-2013, 10:47 PM
RE: My first 1920's set - by Phlogiston - 09-16-2013, 12:07 AM
RE: My first 1920's set - by Electrothaumaturgist - 09-16-2013, 02:10 AM
RE: My first 1920's set - by Radioroslyn - 09-16-2013, 08:12 AM
RE: My first 1920's set - by sam - 09-16-2013, 12:51 PM
RE: My first 1920's set - by marty - 09-16-2013, 01:21 PM
RE: My first 1920's set - by keithw - 09-16-2013, 01:34 PM
RE: My first 1920's set - by Radioroslyn - 09-16-2013, 02:11 PM
RE: My first 1920's set - by Groundhog74 - 09-17-2013, 02:23 PM
RE: My first 1920's set - by Groundhog74 - 09-20-2013, 07:39 AM
RE: My first 1920's set - by Groundhog74 - 09-20-2013, 07:41 AM
RE: My first 1920's set - by Electrothaumaturgist - 09-20-2013, 01:14 PM
RE: My first 1920's set - by TA Forbes - 09-20-2013, 01:28 PM
RE: My first 1920's set - by Groundhog74 - 09-23-2013, 08:30 AM
RE: My first 1920's set - by Gene Pederson - 09-23-2013, 10:35 AM
RE: My first 1920's set - by keithw - 09-24-2013, 09:51 AM
RE: My first 1920's set - by Groundhog74 - 10-22-2013, 05:42 PM
RE: My first 1920's set - by TA Forbes - 10-23-2013, 12:52 PM
RE: My first 1920's set - by Groundhog74 - 10-23-2013, 07:13 PM
RE: My first 1920's set - by exray - 10-23-2013, 08:00 PM
RE: My first 1920's set - by Radioroslyn - 10-24-2013, 02:30 PM
There are currently 7643 online users. [Complete List]
» 2 Member(s) | 7641 Guest(s)
