Philco 90 Chassis Restoration
Use the same method on the potted tone controls. Thought I mention that in the bakelite block pages? Maybe not.
Same thing just somewhat easier.
Chuck
Philco 90 Chassis Restoration - by etech - 03-19-2008, 08:16 PM
[No subject] - by Ron Ramirez - 03-19-2008, 11:36 PM
[No subject] - by etech - 03-19-2008, 11:43 PM
[No subject] - by Texasrocker - 03-20-2008, 12:20 AM
[No subject] - by etech - 03-20-2008, 12:26 AM
[No subject] - by Texasrocker - 03-20-2008, 02:22 AM
[No subject] - by etech - 03-20-2008, 09:50 AM
[No subject] - by Chuck Schwark - 03-20-2008, 08:27 PM
[No subject] - by Ron Ramirez - 05-30-2008, 06:22 PM
Wire size and winding - by AI2V - 05-31-2008, 05:21 PM
[No subject] - by Steve Davis - 05-31-2008, 07:28 PM
There are currently 10108 online users. [Complete List]
» 2 Member(s) | 10106 Guest(s)
