Philco 640 Cabinet Refinishing Chronicles
City: Kentucky
Great thread here..! I also learned from that thread you linked. One thing he doesn't clarify well.. the pore-o-pac really needs to be thinned before you use it. In the can, it has the consistency of peanut butter.. you need to use mineral spirits and make it like paint. The first time I tried to grain fill, I didn't realize this and I couldn't understand why it wouldn't work. Be sure to cut it, or you will find your grain is not filled.
RE: Philco 640 Cabinet Refinishing Chronicles - by Jamie - 09-17-2013, 06:53 AM
Users browsing this thread: 40 Guest(s)
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
Philco 91 Tuning Condenser
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
There are currently 10536 online users. [Complete List] » 2 Member(s) | 10534 Guest(s)
