cracked veneer on a rounded vertical corner
It all depends on how bad it's cracked. Can you post some photos?
RE: cracked veneer on a rounded vertical corner - by Jamie - 09-17-2013, 06:55 AM
There are currently 4273 online users. [Complete List]
» 1 Member(s) | 4272 Guest(s)
