Anybody know what this is?
Hi All;
It could be a stand-off socket that allows You to take measurements of the pins of the Tubes, without turning the Chassis over.. I can't think of the correct name for one of these.. I have some of those.. Or it could be a converter from one type of tube to another type of tube.. But, most likely it is what I first suggested..
THANK YOU marty
Anybody know what this is? - by Eric Adams - 09-17-2013, 03:12 PM
RE: Anybody know what this is? - by marty - 09-17-2013, 03:24 PM
RE: Anybody know what this is? - by marty - 09-17-2013, 04:13 PM
RE: Anybody know what this is? - by Eric Adams - 09-17-2013, 05:19 PM
RE: Anybody know what this is? - by Radioroslyn - 09-17-2013, 06:32 PM
RE: Anybody know what this is? - by Eric Adams - 09-17-2013, 11:35 PM
RE: Anybody know what this is? - by BrendaAnnD - 09-18-2013, 01:06 AM
RE: Anybody know what this is? - by codefox1 - 09-18-2013, 03:33 AM
There are currently 7875 online users. [Complete List]
» 3 Member(s) | 7872 Guest(s)
