Anybody know what this is?
Eric, if no attachments for leads, perhaps it a "socket saver" that was often used in tube testers to save their sockets from continued use and wear. What the hay do I know? I do know that the test sockets were at least made by Pomona Electronics and may still supply them and are in business.
Jerry
Anybody know what this is? - by Eric Adams - 09-17-2013, 03:12 PM
RE: Anybody know what this is? - by marty - 09-17-2013, 03:24 PM
RE: Anybody know what this is? - by marty - 09-17-2013, 04:13 PM
RE: Anybody know what this is? - by Eric Adams - 09-17-2013, 05:19 PM
RE: Anybody know what this is? - by jerryhawthorne - 09-17-2013, 05:39 PM
RE: Anybody know what this is? - by Radioroslyn - 09-17-2013, 06:32 PM
RE: Anybody know what this is? - by Eric Adams - 09-17-2013, 11:35 PM
RE: Anybody know what this is? - by BrendaAnnD - 09-18-2013, 01:06 AM
RE: Anybody know what this is? - by codefox1 - 09-18-2013, 03:33 AM
There are currently 9938 online users. [Complete List]
» 3 Member(s) | 9935 Guest(s)
