Model 89 Code 123 Bandswitch Stuck
The heat trick sounds like it is worth trying before disassembly. Be careful what type of lube you use, some of them are pretty flammable and you don't want have them flash on you with a torch.
As for disassembly, there are usually metal tabs on the back of the pot/switch that will hold the metal casing closed. You can usually use a small screwdriver or needle nose pliers to gently straighten them out and open the back of the case. I've done this on a few other electronic devices with good success.
You sure have been doing your part to bestow the world with nice radios lately! After work, kids, dinner, and more work, I'm lucky to get an hour in the evening to work on things, so my projects progress much more slowly!
Model 89 Code 123 Bandswitch Stuck - by Jamie - 09-17-2013, 07:21 PM
RE: Model 89 Code 123 Bandswitch Stuck - by EricS - 09-17-2013, 07:40 PM
RE: Model 89 Code 123 Bandswitch Stuck - by Jamie - 09-17-2013, 07:55 PM
RE: Model 89 Code 123 Bandswitch Stuck - by Jamie - 09-17-2013, 08:05 PM
RE: Model 89 Code 123 Bandswitch Stuck - by EricS - 09-17-2013, 08:29 PM
RE: Model 89 Code 123 Bandswitch Stuck - by morzh - 09-17-2013, 09:11 PM
RE: Model 89 Code 123 Bandswitch Stuck - by Jamie - 09-18-2013, 06:40 AM
RE: Model 89 Code 123 Bandswitch Stuck - by Jamie - 09-18-2013, 06:45 PM
RE: Model 89 Code 123 Bandswitch Stuck - by morzh - 09-18-2013, 08:05 PM
RE: Model 89 Code 123 Bandswitch Stuck - by EricS - 09-18-2013, 08:10 PM
RE: Model 89 Code 123 Bandswitch Stuck - by EricS - 09-19-2013, 01:15 PM
There are currently 9682 online users. [Complete List]
» 2 Member(s) | 9680 Guest(s)
