Philco 90 restoration
Hi All;
Brenda Ann, You could use an 1206 SMT and make the leads as Long as You like.. Soldering a lead to each side of the unit..
THANK YOU Marty
Philco 90 restoration - by BrendaAnnD - 09-18-2013, 09:37 AM
RE: Philco 90 restoration - by Chuck Schwark - 09-18-2013, 09:52 AM
RE: Philco 90 restoration - by codefox1 - 09-18-2013, 01:56 PM
RE: Philco 90 restoration - by morzh - 09-18-2013, 03:31 PM
RE: Philco 90 restoration - by Radioroslyn - 09-18-2013, 06:21 PM
RE: Philco 90 restoration - by BrendaAnnD - 09-19-2013, 01:13 AM
RE: Philco 90 restoration - by morzh - 09-19-2013, 09:54 AM
RE: Philco 90 restoration - by BrendaAnnD - 09-19-2013, 04:00 PM
RE: Philco 90 restoration - by morzh - 09-19-2013, 07:53 PM
RE: Philco 90 restoration - by marty - 09-19-2013, 08:15 PM
There are currently 11261 online users. [Complete List]
» 2 Member(s) | 11259 Guest(s)
