Philco 34 using 2A7 on Breadboard
Hi All;
Well, I fixed the wire on the Broken coil that I was going to use as a sub, But then it broke on the other side while I was re-installing the Donut coil on the inside, and it kept breaking closer and closer to the inside, untill there was no more wire to get ahold of..
I have a Philco coil form that is a smaller Diameter than the other coil forms that I have, In fact I took it out of one of my other Junk coil forms, I will wind the wire on it, (new wire) and get the proper resistance since it is the input (Antenna coil) side and mount it inside of the other form.. Then I can sub this for the coil that I have in the Philco 34..
THANK YOU Marty
Philco 34 using 2A7 on Breadboard - by marty - 09-19-2013, 08:28 PM
RE: Philco 34 using 2A7 on Breadboard - by marty - 09-20-2013, 08:40 AM
RE: Philco 34 using 2A7 on Breadboard - by marty - 09-20-2013, 10:39 AM
RE: Philco 34 using 2A7 on Breadboard - by marty - 09-20-2013, 12:44 PM
RE: Philco 34 using 2A7 on Breadboard - by marty - 09-21-2013, 11:47 AM
There are currently 10962 online users. [Complete List]
» 2 Member(s) | 10960 Guest(s)
