Fairbanks Morse model 91
Ok ,You got me to thinking.
I think Jerry is on to something here.
Looking to me like the double was originally a single 30 mfd cap.
Someone replaced it with a double 16 and an 8 mfd wired together pos to pos.
What would be the end result if wired together like this.
Those are wired neg. side to chassis ground.
The black can next to it probably has the single 16 mfd in it. It is wired neg. side to transformer center tap like it should be.
What do you guy's think?
Is this possible?
That would make the 100 mfd in the parts list a typo like you guy's said.
Should I try it?
murf
Fairbanks Morse model 91 - by murf - 09-18-2013, 10:00 PM
RE: Faibanks Morse model 91 - by jerryhawthorne - 09-18-2013, 10:37 PM
RE: Faibanks Morse model 91 - by Radioroslyn - 09-18-2013, 11:29 PM
RE: Faibanks Morse model 91 - by Jayce - 09-18-2013, 11:39 PM
RE: Faibanks Morse model 91 - by murf - 09-19-2013, 06:53 AM
RE: Faibanks Morse model 91 - by morzh - 09-19-2013, 09:56 AM
RE: Faibanks Morse model 91 - by murf - 09-21-2013, 01:48 PM
RE: Faibanks Morse model 91 - by jerryhawthorne - 09-21-2013, 02:20 PM
RE: Faibanks Morse model 91 - by murf - 09-21-2013, 03:40 PM
RE: Faibanks Morse model 91 - by BrendaAnnD - 09-21-2013, 04:49 PM
RE: Faibanks Morse model 91 - by BrendaAnnD - 09-21-2013, 04:50 PM
RE: Faibanks Morse model 91 - by jerryhawthorne - 09-21-2013, 05:04 PM
RE: Faibanks Morse model 91 - by murf - 09-21-2013, 05:23 PM
RE: Faibanks Morse model 91 - by murf - 09-21-2013, 05:27 PM
RE: Faibanks Morse model 91 - by jerryhawthorne - 09-21-2013, 05:28 PM
RE: Faibanks Morse model 91 - by murf - 09-21-2013, 05:35 PM
RE: Faibanks Morse model 91 - by Ron Ramirez - 09-21-2013, 05:39 PM
RE: Faibanks Morse model 91 - by jerryhawthorne - 09-21-2013, 05:49 PM
RE: Faibanks Morse model 91 - by murf - 09-22-2013, 09:43 AM
RE: Fairbanks Morse model 91 - by murf - 09-22-2013, 01:34 PM
RE: Fairbanks Morse model 91 - by BrendaAnnD - 09-22-2013, 02:05 PM
RE: Fairbanks Morse model 91 - by murf - 09-22-2013, 02:33 PM
RE: Fairbanks Morse model 91 - by jerryhawthorne - 09-22-2013, 02:47 PM
RE: Fairbanks Morse model 91 - by murf - 09-22-2013, 02:55 PM
There are currently 3991 online users. [Complete List]
» 1 Member(s) | 3990 Guest(s)
