37-116 grill cloth
I wondered the same thing.. seems like everyone who is carrying this new design only sells 18x25.. I wonder if they make it any wider. seems like a sad oversight on their part. there are plenty of the consoles around needing TLC..
37-116 grill cloth - by LASJayhawk - 09-22-2013, 05:27 PM
RE: 37-116 grill cloth - by bfrohwein - 09-22-2013, 06:06 PM
RE: 37-116 grill cloth - by Phlogiston - 09-22-2013, 07:33 PM
