Need help to ID a Fada
I bought several radios today. One of which is this Fada. There are no stickers that mention the model number. Radio Museum doesn't ID it from the tubes.
It has Broadcast and Shortwave..
Tubes are
6D6
6Q7G
25L6G
25Z5
6A7
and a Ballast tube 11541
I've found a Fada that uses the same cabinet, but it is only broadcast. I'm stumped.
Need help to ID a Fada - by Jamie - 09-22-2013, 07:54 PM
RE: Need help to ID a Fada - by morzh - 09-22-2013, 09:20 PM
RE: Need help to ID a Fada - by Arran - 09-22-2013, 10:54 PM
RE: Need help to ID a Fada - by BrendaAnnD - 09-22-2013, 11:19 PM
RE: Need help to ID a Fada - by Jamie - 09-23-2013, 07:55 AM
RE: Need help to ID a Fada - by morzh - 09-23-2013, 06:26 PM
RE: Need help to ID a Fada - by Jamie - 09-23-2013, 08:05 PM
RE: Need help to ID a Fada - by sam - 09-23-2013, 09:59 PM
RE: Need help to ID a Fada - by Arran - 09-24-2013, 12:39 AM
RE: Need help to ID a Fada - by BrendaAnnD - 09-24-2013, 12:55 AM
RE: Need help to ID a Fada - by morzh - 09-24-2013, 10:03 AM
RE: Need help to ID a Fada - by Jamie - 09-24-2013, 10:41 AM
RE: Need help to ID a Fada - by Arran - 09-26-2013, 01:00 AM
There are currently 9594 online users. [Complete List]
» 3 Member(s) | 9591 Guest(s)
