1936 624 6 Volt battery set
You might consider the Playthings of the Past web site. Gary may have a good vibrator there, wouldn't be surprised if he has an NOS one.
Also, you might consider one of the solid state vibrators out there. They are quieter and use less power.....
With respect to power sources, there are MANY batteries and chargers out there. Several are for burglar alarms.... they have an adequate amount of power to run your set for two to three hours. There are also small plug in chargers that do a great job recharging your 6V battery.
Of course there are also the small lead/acid 6V batteries used for lawn mowers, etc....
1936 624 6 Volt battery set - by bfrohwein - 06-17-2013, 03:57 PM
RE: 1936 624 6 Volt battery set - by morzh - 06-17-2013, 06:02 PM
RE: 1936 624 6 Volt battery set - by Mondial - 06-17-2013, 09:23 PM
RE: 1936 624 6 Volt battery set - by morzh - 06-17-2013, 10:43 PM
RE: 1936 624 6 Volt battery set - by Mondial - 06-18-2013, 12:21 AM
RE: 1936 624 6 Volt battery set - by bfrohwein - 06-18-2013, 03:00 PM
RE: 1936 624 6 Volt battery set - by morzh - 06-18-2013, 03:29 PM
RE: 1936 624 6 Volt battery set - by Mondial - 06-18-2013, 08:57 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 06-18-2013, 09:50 PM
RE: 1936 624 6 Volt battery set - by Arran - 06-18-2013, 10:06 PM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 06-18-2013, 11:26 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 06-25-2013, 11:05 AM
RE: 1936 624 6 Volt battery set - by bfrohwein - 09-22-2013, 04:23 PM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 09-22-2013, 06:07 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 09-22-2013, 06:21 PM
RE: 1936 624 6 Volt battery set - by TA Forbes - 09-22-2013, 08:20 PM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 09-22-2013, 11:03 PM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 09-22-2013, 11:04 PM
RE: 1936 624 6 Volt battery set - by Arran - 09-22-2013, 11:42 PM
RE: 1936 624 6 Volt battery set - by TA Forbes - 09-23-2013, 09:39 PM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 09-23-2013, 11:18 PM
RE: 1936 624 6 Volt battery set - by TA Forbes - 09-24-2013, 01:46 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 10-27-2013, 11:41 PM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 10-28-2013, 05:27 AM
RE: 1936 624 6 Volt battery set - by Mondial - 10-28-2013, 08:50 AM
RE: 1936 624 6 Volt battery set - by bfrohwein - 10-28-2013, 01:21 PM
RE: 1936 624 6 Volt battery set - by Mondial - 10-28-2013, 04:38 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 10-28-2013, 08:07 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 10-28-2013, 11:40 PM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 10-29-2013, 04:46 AM
RE: 1936 624 6 Volt battery set - by bfrohwein - 10-29-2013, 08:10 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 10-30-2013, 06:25 PM
RE: 1936 624 6 Volt battery set - by bfrohwein - 12-14-2013, 01:39 AM
RE: 1936 624 6 Volt battery set - by BrendaAnnD - 12-14-2013, 03:00 AM
RE: 1936 624 6 Volt battery set - by bfrohwein - 12-14-2013, 03:17 AM
RE: 1936 624 6 Volt battery set - by Radioroslyn - 12-15-2013, 11:53 AM
RE: 1936 624 6 Volt battery set - by bfrohwein - 12-15-2013, 01:32 PM
The speaker table error?
Philco 70 antenna lead
There are currently 3210 online users. [Complete List]
» 2 Member(s) | 3208 Guest(s)
