Philco 112 Lowboy restoration (caution, lots of images)
Hi
The blistering on that coil is probably from heat.
You are correct in that none of the capacitors in the large black filter can were originally electrolytic - they were wound paper and foil, as you have seen for yourself.
You are going to have a VERY nice radio when you get it finished. Congrats, and thank you for sharing the photos!
[No subject] - by PhilcoPhil - 03-27-2008, 05:49 PM
[No subject] - by Ron Ramirez - 03-27-2008, 05:51 PM
[No subject] - by gary rabbitt - 04-06-2008, 01:32 PM
[No subject] - by BDM - 04-06-2008, 06:15 PM
[No subject] - by audin - 04-08-2008, 02:38 PM
[No subject] - by audin - 04-08-2008, 02:41 PM
[No subject] - by audin - 04-08-2008, 02:59 PM
There are currently 4411 online users. [Complete List]
» 1 Member(s) | 4410 Guest(s)
