40-180 Recap - Looking for tips/advice
yes, no-pumice GoJo.
In fact some people tell that Windex makes things dull, but I have used it on many things, including my fully custom kitchen cabinets, and in 5 years they did not suffer (no, I do not use it too often). For things like dials Windex might work, but I am in the habit of trying it on small inconspicuous area first.
Alcohol works well on many things plastic.
RE: 40-180 Recap - Looking for tips/advice - by morzh - 09-23-2013, 11:13 AM
