Need help to ID a Fada
Thanks again for all of the time spent hunting info. The radio plays great, has updated electrolytics and looks like it was gone through sometime in the past 5 years. I haven't had time to check voltages yet (not sure what they should be anyway), but I'll get to it eventually. Sooner or later I'll end up selling it.
Need help to ID a Fada - by Jamie - 09-22-2013, 07:54 PM
RE: Need help to ID a Fada - by morzh - 09-22-2013, 09:20 PM
RE: Need help to ID a Fada - by Arran - 09-22-2013, 10:54 PM
RE: Need help to ID a Fada - by BrendaAnnD - 09-22-2013, 11:19 PM
RE: Need help to ID a Fada - by Jamie - 09-23-2013, 07:55 AM
RE: Need help to ID a Fada - by morzh - 09-23-2013, 06:26 PM
RE: Need help to ID a Fada - by Jamie - 09-23-2013, 08:05 PM
RE: Need help to ID a Fada - by sam - 09-23-2013, 09:59 PM
RE: Need help to ID a Fada - by Arran - 09-24-2013, 12:39 AM
RE: Need help to ID a Fada - by BrendaAnnD - 09-24-2013, 12:55 AM
RE: Need help to ID a Fada - by morzh - 09-24-2013, 10:03 AM
RE: Need help to ID a Fada - by Jamie - 09-24-2013, 10:41 AM
RE: Need help to ID a Fada - by Arran - 09-26-2013, 01:00 AM
There are currently 6557 online users. [Complete List]
» 2 Member(s) | 6555 Guest(s)
