41-95 schematic
Try to get a pic & check the model # again.
Was going to recap & check the resistors on the Philco for
sure, & then go into the eliminator to see what that's
like. Have read about those eliminators, but never had
one on the bench.
A thousand pardons---just went out to check the serial
#, & it is 41-95. Had the set out in the shed, & it was
kind of dark. Shows up better out in the sun.
Beitmans still doesn't show this model #.
Thanks. Jim
41-95 schematic - by brownie45 - 09-25-2013, 10:30 AM
RE: 41-99 schematic - by marty - 09-25-2013, 11:00 AM
RE: 41-99 schematic - by Carl Travis - 09-25-2013, 11:04 AM
RE: 41-99 schematic - by marty - 09-25-2013, 11:07 AM
RE: 41-99 schematic - by brownie45 - 09-25-2013, 01:32 PM
RE: 41-99 schematic - by BrendaAnnD - 09-25-2013, 03:50 PM
RE: 41-99 schematic - by klondike98 - 09-25-2013, 03:59 PM
RE: 41-99 schematic - by brownie45 - 09-25-2013, 07:12 PM
RE: 41-95 schematic - by brownie45 - 09-26-2013, 01:30 PM
RE: 41-95 schematic - by brownie45 - 11-23-2013, 11:04 AM
RE: 41-95 schematic - by Raleigh - 11-29-2013, 04:52 PM
RE: 41-95 schematic - by brownie45 - 11-30-2013, 07:39 AM
RE: 41-95 schematic - by brownie45 - 12-11-2013, 09:27 PM
RE: 41-95 schematic - by Radioroslyn - 12-11-2013, 11:55 PM
There are currently 6414 online users. [Complete List]
» 1 Member(s) | 6413 Guest(s)
