Atwater Kent 328 Early
Hi All;
Eric, I would carefully take off the outer covers and look for internal wire shorts, caused by broken wires or broken insulation.. One possible way to fix it after the covers are removed is to use Liquid Tape arround the various wires and then put the covers back on.. And recheck for any shorts.. Look under Joernone for his fixing a transformer..
http://www.youtube.com/watch?v=UN4e855Ae...2&index=11
http://www.youtube.com/watch?v=0kB5zn3LH...38A28F2222
http://www.youtube.com/watch?v=2NkGw-kw7...38A28F2222
http://www.youtube.com/watch?v=IQlLKDMla...38A28F2222
http://www.youtube.com/watch?v=a31C5MsH-...38A28F2222
THANK YOU Marty
Atwater Kent 328 Early - by Eric - 09-24-2013, 08:09 PM
RE: Atwater Kent 328 Early - by Radioroslyn - 09-24-2013, 09:22 PM
RE: Atwater Kent 328 Early - by Eric - 09-25-2013, 11:32 AM
RE: Atwater Kent 328 Early - by Mondial - 09-25-2013, 02:51 PM
RE: Atwater Kent 328 Early - by Eric - 09-25-2013, 06:14 PM
RE: Atwater Kent 328 Early - by marty - 09-25-2013, 06:33 PM
RE: Atwater Kent 328 Early - by Eric - 09-25-2013, 07:31 PM
RE: Atwater Kent 328 Early - by Arran - 09-25-2013, 10:35 PM
RE: Atwater Kent 328 Early - by Eric - 09-25-2013, 11:08 PM
RE: Atwater Kent 328 Early - by Mondial - 09-26-2013, 12:05 AM
RE: Atwater Kent 328 Early - by Arran - 09-26-2013, 12:08 AM
RE: Atwater Kent 328 Early - by Eric - 09-26-2013, 03:18 PM
RE: Atwater Kent 328 Early - by Eric - 10-06-2013, 11:29 AM
RE: Atwater Kent 328 Early - by Mondial - 10-06-2013, 11:51 AM
RE: Atwater Kent 328 Early - by Eric - 10-07-2013, 08:54 PM
RE: Atwater Kent 328 Early - by Eric - 10-08-2013, 06:56 PM
RE: Atwater Kent 328 Early - by Mondial - 10-08-2013, 08:28 PM
RE: Atwater Kent 328 Early - by Eric - 10-09-2013, 11:10 AM
RE: Atwater Kent 328 Early - by Eric - 10-09-2013, 05:15 PM
RE: Atwater Kent 328 Early - by Mondial - 10-09-2013, 06:39 PM
RE: Atwater Kent 328 Early - by Eric - 10-10-2013, 03:28 PM
RE: Atwater Kent 328 Early - by Mondial - 10-11-2013, 08:31 AM
RE: Atwater Kent 328 Early - by Eric - 10-11-2013, 08:15 PM
RE: Atwater Kent 328 Early - by Mondial - 10-11-2013, 11:16 PM
RE: Atwater Kent 328 Early - by Eric - 10-12-2013, 11:38 AM
RE: Atwater Kent 328 Early - by Mondial - 10-13-2013, 10:31 AM
RE: Atwater Kent 328 Early - by Eric - 10-13-2013, 12:18 PM
There are currently 7740 online users. [Complete List]
» 3 Member(s) | 7737 Guest(s)
