40-180 Recap - Looking for tips/advice
I decided to peek in the drum, and see how hard it would be to replace the wires. It turns out it's very easy. All you have to do is take out the staples around the top and the bottom. Leave the ones along the seam in place. Then unsolder the wire on the metal tab, and carefully slide the drum off.
It's basically a big X inside with wire wrapped around it and tapped in a few places. There is also a capacitor and resistor in parallel in there on the white wire that runs to the antenna terminal on the radio. I didn't notice them on the schematic at first.
I desoldered the terminals, cut new wire to the same length, and soldered them back on the new wire. Replaced the cap and resistor as long as I was in there. Slid the cardboard back on, re-stapled it around the top and bottom, and it's good to go again.
I attached a picture in case anyone wanted to know what it looks like.
RE: 40-180 Recap - Looking for tips/advice - by Nick3092 - 09-25-2013, 09:33 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
There are currently 2990 online users. [Complete List]
» 2 Member(s) | 2988 Guest(s)
