Motorola 10Y Parts Set
The 2nd of two radios I picked up today for parts. This puppy is hurtin'--suffering from water damage on the bottom. One foot fell off when we put it in the trunk. Round center plastic is cracked. But both sets have all their tubes!
[Image: http://i1185.photobucket.com/albums/z345...12ff59.jpg]
[Image: http://i1185.photobucket.com/albums/z345...57f470.jpg]
[Image: http://i1185.photobucket.com/albums/z345...c767da.jpg]
Gene
Motorola 10Y Parts Set - by Gene Pederson - 09-26-2013, 04:27 PM
RE: Motorola 10Y Parts Set - by codefox1 - 09-26-2013, 05:48 PM
RE: Motorola 10Y Parts Set - by BrendaAnnD - 09-26-2013, 06:07 PM
RE: Motorola 10Y Parts Set - by PhilcoJohn - 09-26-2013, 07:34 PM
RE: Motorola 10Y Parts Set - by Jayce - 09-26-2013, 07:53 PM
RE: Motorola 10Y Parts Set - by Gene Pederson - 09-26-2013, 08:26 PM
RE: Motorola 10Y Parts Set - by Arran - 09-26-2013, 10:16 PM
There are currently 9591 online users. [Complete List]
» 2 Member(s) | 9589 Guest(s)
