Speaker repair sources update
I used the Speaker Shop before, they are a decent house.
That was after I contacted Hank and he said (that was 2.5 years ago) he would not take the job.
They re-coned my 20's speaker.
RE: Speaker repair sources update - by y2kbruce - 09-25-2013, 12:57 PM
RE: Speaker repair sources update - by morzh - 09-26-2013, 09:42 PM
RE: Speaker repair sources update - by Arran - 09-26-2013, 11:55 PM
RE: Speaker repair sources update - by Eric Adams - 09-27-2013, 12:03 AM
RE: Speaker repair sources update - by BrendaAnnD - 09-27-2013, 01:21 AM
RE: Speaker repair sources update - by Kenradio - 09-27-2013, 03:43 PM
RE: Speaker repair sources update - by Eric Adams - 09-27-2013, 06:05 PM
RE: Speaker repair sources update - by BrendaAnnD - 09-27-2013, 08:03 PM
RE: Speaker repair sources update - by Eric Adams - 09-27-2013, 09:43 PM
There are currently 8164 online users. [Complete List]
» 1 Member(s) | 8163 Guest(s)
