How does one clean an older philco volume control?
So my 112 has a type of volume control I have never seen before. Sort of a spring-loaded brass wheel running around inside a resistive metal band. I'm guessing that after 77 years it could do with a cleaning (though i have not heard audio through it yet...so maybe it is fine? it appears scratchy when i monitor its resistance with my multimeter).
So is there a good way to clean these? Should I just leave it alone?
Here is a picture of the workings:
[Image: http://farm3.staticflickr.com/2220/23672...99fe_z.jpg]
Crazy Philco volume control by Audin, on Flickr
http://www.flickr.com/photos/audin/2367257525/
How does one clean an older philco volume control? - by audin - 03-29-2008, 05:44 PM
[No subject] - by Alan Douglas - 03-29-2008, 09:32 PM
[No subject] - by exray - 03-29-2008, 09:34 PM
[No subject] - by audin - 03-31-2008, 05:12 PM
[No subject] - by Alan Douglas - 04-01-2008, 12:15 PM
There are currently 9140 online users. [Complete List]
» 2 Member(s) | 9138 Guest(s)
