Brought home a fada
Arran thanks for your comments. Yes, NY call letters. The flash tuner as far as I know was only set up for NY stations. It is basically little more than a "microswitch" on the plastic dial that has indents on it to trigger a light when the tuner reaches a NY station. The radio was sold the the great grandfather of the people I bought it from and indeed in the NY area. It will be a challenge to try to get to the tuner with all the stuff in front of it and see what I can figure out.
Regards, Jerry
PS: Arran, don't worry about the price, at my age, I don't worry about things like that. It's a hobby.
Brought home a fada - by jerryhawthorne - 09-28-2013, 10:58 PM
RE: Brought home a fada - by Arran - 09-28-2013, 11:16 PM
RE: Brought home a fada - by jerryhawthorne - 09-29-2013, 02:17 AM
RE: Brought home a fada - by Electrothaumaturgist - 09-29-2013, 04:58 AM
RE: Brought home a fada - by PhilcoJohn - 09-29-2013, 09:02 AM
RE: Brought home a fada - by Jamie - 09-29-2013, 09:24 AM
RE: Brought home a fada - by Jayce - 09-29-2013, 03:32 PM
RE: Brought home a fada - by jerryhawthorne - 09-29-2013, 04:06 PM
RE: Brought home a fada - by Raymanretro - 09-29-2013, 08:45 PM
RE: Brought home a fada - by Arran - 09-30-2013, 02:20 AM
RE: Brought home a fada - by morzh - 09-30-2013, 11:20 AM
RE: Brought home a fada - by TA Forbes - 09-30-2013, 11:25 AM
RE: Brought home a fada - by jerryhawthorne - 09-30-2013, 02:51 PM
RE: Brought home a fada - by jerryhawthorne - 09-30-2013, 07:41 PM
RE: Brought home a fada - by jerryhawthorne - 10-02-2013, 12:11 AM
There are currently 5402 online users. [Complete List]
» 5 Member(s) | 5397 Guest(s)
AvatarAvatarAvatarAvatar
