Brought home a fada
Jayce, I have not looked at the speaker much other than blowing off years of dust. The cone itself shows some warping something to look in to in the future. Perhaps a little light spray of water on it might have it relax a bit? Hard to see in the picture of it. A fairly rigid spider on it so hopefully the voice coil is well centered. Time will tell after I solve the tuner problem.
It has had repeated applications of pbblaster and a few light taps, no joy yet. I will be patient.
Jerry
PS: This radio came down through the Fulco family. A family of 6 all of which are musically very talented. There house was filled with recording gear. To bad the radio wasn't a Philco or I could have obtained the Fulco's Philco!
Link to the family:
http://www.meetthefulcos.com/Videos.html
Brought home a fada - by jerryhawthorne - 09-28-2013, 10:58 PM
RE: Brought home a fada - by Arran - 09-28-2013, 11:16 PM
RE: Brought home a fada - by jerryhawthorne - 09-29-2013, 02:17 AM
RE: Brought home a fada - by Electrothaumaturgist - 09-29-2013, 04:58 AM
RE: Brought home a fada - by PhilcoJohn - 09-29-2013, 09:02 AM
RE: Brought home a fada - by Jamie - 09-29-2013, 09:24 AM
RE: Brought home a fada - by Jayce - 09-29-2013, 03:32 PM
RE: Brought home a fada - by jerryhawthorne - 09-29-2013, 04:06 PM
RE: Brought home a fada - by Raymanretro - 09-29-2013, 08:45 PM
RE: Brought home a fada - by Arran - 09-30-2013, 02:20 AM
RE: Brought home a fada - by morzh - 09-30-2013, 11:20 AM
RE: Brought home a fada - by TA Forbes - 09-30-2013, 11:25 AM
RE: Brought home a fada - by jerryhawthorne - 09-30-2013, 02:51 PM
RE: Brought home a fada - by jerryhawthorne - 09-30-2013, 07:41 PM
RE: Brought home a fada - by jerryhawthorne - 10-02-2013, 12:11 AM
