37-116 tube shields
If the problem is just rust, put some naval jelly on them and let them sit for about an hour. Then rinse them off and the rust will be gone. You can get naval jelly at any hardware store. I use it all the time to get rid of rust.
37-116 tube shields - by Ronin61 - 09-29-2013, 01:01 PM
RE: 37-116 tube shields - by morzh - 09-29-2013, 04:29 PM
RE: 37-116 tube shields - by codefox1 - 09-29-2013, 04:48 PM
RE: 37-116 tube shields - by GarySP - 09-29-2013, 08:29 PM
RE: 37-116 tube shields - by Jamie - 09-29-2013, 09:00 PM
RE: 37-116 tube shields - by Ron Ramirez - 09-29-2013, 09:10 PM
RE: 37-116 tube shields - by Ronin61 - 09-29-2013, 09:27 PM
