Stewart-Warner 950 battery set
Huh, ok. Guess it was an inertia thing then. Either the package was caused to accelerate fast enough to make those transformers sheer off or was caused to stop suddenly. Either way, I hope you can get it repaired. Guess this is why I always look for radios withing driving distance from me as I have no trust in any of the delivery services anymore. That and even I don't know how to pack a radio for shipment, so I also tend to sell locally.
Stewart-Warner 950 battery set - by BrendaAnnD - 09-30-2013, 11:34 PM
RE: Stewart-Warner 950 battery set - by Jayce - 10-01-2013, 12:17 AM
RE: Stewart-Warner 950 battery set - by Jayce - 10-01-2013, 11:35 AM
RE: Stewart-Warner 950 battery set - by Arran - 10-01-2013, 11:24 PM
RE: Stewart-Warner 950 battery set - by marty - 10-02-2013, 10:30 AM
RE: Stewart-Warner 950 battery set - by sam - 10-04-2013, 11:57 AM
RE: Stewart-Warner 950 battery set - by Arran - 10-05-2013, 05:29 AM
RE: Stewart-Warner 950 battery set - by Arran - 10-05-2013, 08:55 AM
RE: Stewart-Warner 950 battery set - by marty - 10-05-2013, 10:49 AM
RE: Stewart-Warner 950 battery set - by Arran - 10-06-2013, 03:45 AM
There are currently 7289 online users. [Complete List]
» 1 Member(s) | 7288 Guest(s)
