Philco 640 Cabinet Refinishing Chronicles
Thanks Steve. For Option #2, should I do a light sanding with 320 grit after the first coat of sanding sealer, prior to the application of grain filler? Or just leave it as is?
RE: Philco 640 Cabinet Refinishing Chronicles - by Geoff - 10-01-2013, 02:42 PM
Users browsing this thread: 16 Guest(s)
Philco 91 Tuning Condenser
There are currently 6903 online users. [Complete List]
» 2 Member(s) | 6901 Guest(s)
