Philco 640 Cabinet Refinishing Chronicles
I don't use sanding sealer, so that's up to you. And there is no need to apply clear before toning. All that will do is give your toner the tendency to have runs. Whatever you do, don't use stain.
RE: Philco 640 Cabinet Refinishing Chronicles - by Jamie - 10-01-2013, 05:16 PM
Users browsing this thread: 39 Guest(s)
Philco 91 Tuning Condenser
There are currently 10171 online users. [Complete List]
» 2 Member(s) | 10169 Guest(s)
