I bought a Philco 37-650 today..
Here is an update on this project.. I have the cabinet 99% finished. I just need to add the decal and shoot some clear over it. The chassis is on my bench and I'm working through it slowly.
Which decal is the proper decal? I don't want to screw this up..
I bought a Philco 37-650 today.. - by Jamie - 08-18-2013, 03:54 PM
RE: I bought a Philco 37-650 today.. - by KCMike - 08-18-2013, 10:55 PM
RE: I bought a Philco 37-650 today.. - by Jamie - 08-19-2013, 07:15 AM
RE: I bought a Philco 37-650 today.. - by Jamie - 08-19-2013, 01:36 PM
RE: I bought a Philco 37-650 today.. - by AI2V - 08-20-2013, 03:59 PM
RE: I bought a Philco 37-650 today.. - by AI2V - 08-21-2013, 11:04 AM
RE: I bought a Philco 37-650 today.. - by Jamie - 08-21-2013, 03:43 PM
RE: I bought a Philco 37-650 today.. - by Arran - 08-22-2013, 10:44 PM
RE: I bought a Philco 37-650 today.. - by Jamie - 10-02-2013, 08:50 AM
RE: I bought a Philco 37-650 today.. - by Jamie - 10-06-2013, 04:15 PM
RE: I bought a Philco 37-650 today.. - by PT57 - 10-20-2013, 03:03 PM
RE: I bought a Philco 37-650 today.. - by Jamie - 10-20-2013, 03:54 PM
RE: I bought a Philco 37-650 today.. - by PT57 - 10-20-2013, 03:56 PM
RE: I bought a Philco 37-650 today.. - by Jamie - 10-20-2013, 04:58 PM
RE: I bought a Philco 37-650 today.. - by Jamie - 11-01-2013, 06:46 PM
RE: I bought a Philco 37-650 today.. - by PT57 - 11-01-2013, 09:23 PM
Philco 91 Tuning Condenser
