Philco 640 Cabinet Refinishing Chronicles
Threads: 73
City: Riverside, CA
One other question I had about this radio is about one of the knobs. RenovatedRadios lists this knob as a bandswitch knob for the 640:
[Image: http://antiqueradios.com/gallery/main.ph...alNumber=1]
However, this picture of my radio shows that the bandswitch knob is round. It appears to be original.
After a Google search for the 640 I found that most pictures had a round knob but some had this switch knob. Which knob is accurate for the 640?
- Geoff
(This post was last modified: 10-03-2013, 01:38 PM by Geoff.)
RE: Philco 640 Cabinet Refinishing Chronicles - by Geoff - 10-03-2013, 01:37 PM
Users browsing this thread: 36 Guest(s)
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
Philco 91 Tuning Condenser
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
There are currently 10309 online users. [Complete List] » 1 Member(s) | 10308 Guest(s)
