Philco 640 Cabinet Refinishing Chronicles
Regarding the band switch knob, the Renovated Radios repro is for 1937 and 1938 models.
Notice it says 1937: followed by several different partial model numbers. He did it that way, I think to keep from repeating 37-11, 37-116, 37-610, etc. You are correct, the original knob was round and black (not brown, or even dark brown).
RE: Philco 640 Cabinet Refinishing Chronicles - by Ron Ramirez - 10-03-2013, 07:23 PM
Users browsing this thread: 38 Guest(s)
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
Philco 91 Tuning Condenser
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
There are currently 10428 online users. [Complete List] » 2 Member(s) | 10426 Guest(s)
