Bakelite Condenser
Please bear with these questions of a rank neophyte;
What is the function of the bakelite condenser?
What are the symptoms that a malfunctioning one would exhibit?
I'm attempting to tackle my first restoration (a Model 40-130) and I'm trying to learn as I go. The bakelite assembly may be in need of help (bulging tar), but before I do a rebuild and replace the two caps I'd like to know more about it.
Bakelite Condenser - by Guest - 03-31-2008, 07:13 PM
[No subject] - by 49Stude63 - 03-31-2008, 07:47 PM
[No subject] - by Chuck Schwark - 03-31-2008, 07:48 PM
[No subject] - by Texasrocker - 04-01-2008, 12:59 AM
[No subject] - by Guest - 04-01-2008, 07:16 PM
Eico 232 VTVM Schematic
There are currently 6574 online users. [Complete List]
» 2 Member(s) | 6572 Guest(s)
